Thread contains 8.1.x nightly build changelogs from 2026 until EOL.
Not all nightly builds contain release notes, so some days will have no posts.
Nightly Changelog: 8.1.53-SNAPSHOT-b20260205
IGN-15360: Bump bundled Cirrus Link modules to 4.0.33
Updated Ignition Cloud Edition bundled Cirrus Link MQTT modules to version 4.0.33
IGN-15310: [8.1] Disconnect IEC 61850 client on redundancy failover
IEC 61850: redundant nodes now disconnect from IEDs on transition from active to inactive, instead of just disabling reports.
Nightly Changelog: 8.1.54-SNAPSHOT-b20260320
IGN-15573: Backport: SFC: Meeting Cancel Condition in Parallel Block Results in Chart Getting Stuck - Unable to Cancel
Fixed an issue where the chart may get stuck after meeting the cancel condition for a Parallel Element.
**IGN-15494: Backport: Dataset Tag with DateTime Column on European Gateway Locale Loses Data on Restart **
Fixed an issue with Dates inside a dataset being set to null when using certain languages.
Nightly Changelog: 8.1.54-SNAPSHOT-b20260402
IGN-15754: Backport: XY Chart: "Bullets" component properties are not fully applied
Removed unused XY Chart bullet height and width properties in favor of radius property for Circle bullets. Added truncate and hideOversized properties to Label bullet configuration to allow control of Label overflow behavior, both True by default. Added getFillFromObject property to bullet tooltip configuration to allow control of where the tooltip gets its background color, True by default.
Nightly Changelog: 8.1.54-SNAPSHOT-b20260601
IGN-14555: Deadlock on binding shutdown when expression uses a property function inside a tag function
A deadlock between the perspective-worker and perspective-queue no longer occurs when an expression using a property function is nested inside a tag function is shutdown during execution.
Nightly Changelog: 8.1.55-SNAPSHOT-b20260622
IGN-16442: BACKPORT: Publish release artifacts + launchers to new ia-releases/releases.inductiveautomation.com S3 bucket
The S3 bucket to which Ignition is published, including hosted launchers, changes from files.inductiveautomation.com to releases.inductiveautomation.com. This change includes hosted launchers. Two S3 key prefixes are shorted as well, release/ia/ to release/ and builds/nightly/ to nightly/.
Nightly Changelog: 8.1.55-SNAPSHOT-b20260623
IGN-16640: Backport: Perspective Component Overlays and diagnostic information are not translatable
Fixed an issue where text in a Perspective component's quality overlay and quality diagnostic popover was not translated according to the active session locale.
Nightly Changelog: 8.1.55-SNAPSHOT-b20260715
**IGN-15866: Backport: GAN Ping Time in Status page displays N/A on incoming connection. **
Fixed an issue where the Gateway Network status page incorrectly displayed "N/A" for incoming connection ping metrics on 8.1 gateways. This a backport fix for IGN-15901.
