Only a couple notable items merged in yesterday, most significant being an update to the Look and Feel (visual styling). Lots more in the pipeline, thanks for your continued participation!
Platform - Designer/ Vision Client
Upgrade Look and Feel
Numerous fixes, updates, icon additions to the designer and Vision clients
Perspective
FB11035: Fixed XY Chart when binding to tag history data
Change includes new inputFormat axes property to specify custom date formats and new default format to match the format provided by tag history.
Rather than make a new post, I am going to just add on to the existing one, and change the version in the title so that people can bookmark this one post to visit when they are interested in changes. Also make it easier to see a list of all changes since some previous date.
Ignition Platform
FB11614 Versioned JRE upgrading
The embedded JRE is now managed much more intelligently when upgrading and installing.
FB10394: Replace Static User Manual Links in the Software with Permalinks
No longer error on null dates in a Date array during export
Fixes for legacy system.tag.browseTags
Legacy browse function no longer returns udt definitions, to match 7.x behavior
Legacy browse function now returns memory, expression and query tags when the tagType is specified as “DB”, to match 7.x behavior
Folders and udt instances are no longer filtered, and will appear with filtered atomic tags in browse results. Before this, the presence of folders/udts in the results was inconsistent for both 7.x and 8.0. Now folders and udt instances are always in the results, and the user can run further browse calls on them to retrieve more filtered atomic tags. Note that this change affects both the legacy and the 8.0 specific system.tag.browse function.
Perspective
10954: Copy/Paste from a coordinate container in percent mode no longer reduces objects size
FB11062: Fixed error overlay for clickable inputs
disable event propagation to stop child component from firing when svg on click
FB11618: Fixed issue where Coordinate Container Percent modes would render a number components at the wrong size
Legacy conversion fixes 11_06
Fixed a bug with an incorrect folder chain id on a udt override
Lots of tag ranking work to ensure the correct ordering of udts, and ensure that no member of a udt definition can ever be loaded before any udt instance
Now handles the scenario of duplicate udt member ids existing for different udt definitions
Added a CustomerLegacyTagConverter with a custom logging filter that allows conversion issues of a customer’s internal db to be far more easily diagnosed.
