Nightly Changelog: 8.0.0- beta.20181210-13
Here are some changes published this week.
IALabs Modules
FB11993: Webdev module now loads properly in the designer
Ignition Platform
FB11954 Add custom properties to tag browse model
FB10926 Removed type column from multi-instance wizard. Defaults parameter math to integer formatting.
FB11786: Fixed inability to move/copy tags between providers
FB12000: Change app_quit_handler logger to debug
FB11942 NPE When Creating UDT Instance In Non-Default Provider
FB11717 Tag rename to existing name shows error after closing dialog
FB11950: Using system.tag.exists() In The Script Console Returns False For Any tag path which does not exist fixed
FB11994, FB11991, FB11947, FB11895 Various Launcher fixes
Added the ability to modify the gateway address for an Application in the launcher. Fixed Launch + create shortcut that was broken for the Vision Client Launcher. Added the Gateway Address to the collapsable titled pane in the Vision Client Launcher. Updated the launcher icon to the correct one.
FB 11750 and FB 11987: TagEditorDialog fixes
The formatString field was not updating in the UI when the tag’s datatype was changed to a date. Also FB 11987: Fixed NPE when creating a new tag and hitting Apply before OK.
FB10867, FB10868, FB11053: Security Levels and Identity Providers Gateway Config UIs
FB11443 Vision Branding Updates
Threw away the old layout manager and replaced it with Miglayout for the login screen.
Project image icon now scaled to max of 90px (default).The project title appears now when there is a message.The Close button has been updated to match the invision prototype. The login content is now wrapped in a scrollpane so the user can always get to the content.
Misc
Custom Properties and much more!
This is a continuation of the “custom properties” PR from before. Also fixed the issue with system defined parameter bindings, improved the binding editing experience, and fixed a range of editing issues.
Barcode Component
Component that allows users to input barcodes using their own scanners. Uses prefix/postfix settings to capture barcode, or a regex pattern.
(re) implemented OPC UA connection failover
Set configured keep-alive settings on OpcUaClientConfigBuilder
Call ResendData when subscription notification data is lost
Perspective
FB11922: NPE when pressing Escape key while on page configuration screen
FB12011: Tag reference in an expression binding now works without specifying a provider if a default provider is specified on the project.
The expression editor’s tag picker now inserts a tag path with [] at the beginning when picking from the default provider.
FB12009, FB11967, FB11778, FB11990, FB11968: More popup revisions related to components and popups themselves
FB10614: Better defaults for tag drop component creation
FB12032: Indirect Tag Bindings With Interpolated Values References Which Contain an Underscore Now Work
FB11245: Project Title Changes Now Persist In Perspective Project
FB11019: Updated Perspective favicon
FB11111: Bidirectional checkbox on bindings are now disabled if transforms exist
Vision
FB12013: Lazy load web browser Vision component to prevent startup error
3 posts were split to a new topic: Barcode scanner input component questions
