Hi,I am having an issue with high cpu usage even i do noting in designer or client .every time ,i can find an warning named NioEventLoop.any one have ideas?Thanks!.
Look at your log: those clock drift events usually mean your system is bogging down for other reasons–usually a DB on the same box, or if a VM, the hypervisor starving your gateway. The busy event loops are likely just the flurry of threads discovering they’ve all timed out together because of the pause-the-world.
Fix your starvation problem first.
Also, switch to G1GC. The concurrent-mark-sweep garbage collector is horrible. Start here:
Yes, change your first two “Additional Parameters” to look like this:
wrapper.java.additional.1=-XX:+UseG1GC
wrapper.java.additional.2=-XX:MaxGCPauseMillis=100
