Good afternoon, I recently started using Ignition, but when using EASYCHART, I notice the following:
When I try to run the interface created in the Designer using LAUNCH PROJECT, no data is displayed in my chart, even the EasyChart is displayed in red. However, if I run it in the same Designer, the chart or data is displayed without any problems.
Could someone help me with this problem?
Thanks in advance.
I've attached photos.
Hello Anthony, welcome to the forums. This is a common issue to encounter at first, partially because the error does not popup.
In the Vision Client, if you go to the help tab at the top the diagnostics menu will contain the output console. The console contains the error that is causing this problem.
You will quickly discover through searching the error it is related to your Vision project permissions, so check out the: Vision Project Properties | Ignition User Manual
Gracias por el apoyo.
