I am trying to setup an SSO sign-on method for our Ignition 8.1 gateway. We tested SAML2 in our lab environment and even without attribute mapping I could get a clear response. When I updated the attribute mapping, everything went to the correct place.
Now I am attempting to do the same in production environment and I see the following behavior:
After clicking test login, the browser momentarily switches to the SSO login screen but before I can see any of the text entry fields, it re-directs back the Ignition gateway.
Back at the gateway, I get the message “No IdP Response Data” I have attached the full log message but the last line says "Expected response destination to be ‘https://removed for security:8043/data/federate/callback/saml’ but got ‘null’.
When creating the identity provider, all I am doing is importing the metadata from the url provided by our IT department. I have tried all combinations of validate response/assertion signatures but it doesn’t make any difference.
Does anyone with experience on this same issue have any advice or things we might try for trouble shooting?
Thanks,
Nick
error log.txt (6.3 KB)
