Hi everyone,
I'm attempting to copy the history from one tag to another.
It's complaining that "No values provided" but I have checked the data is in the array.
Here is the code I am using:
sourcePath='[MQTT Engine]Edge Nodes/XNEELO 002/seneca/C8F9810F26XX/avi/abalone/zgprs3001/custom/FLOW_1_FB'
destPath='[default]Edge Nodes/projects/avi/abalone/zgprs3005/custom/FLOW_1_FB'
endTime = system.date.now()
startTime = system.date.addWeeks(endTime, -1)
dataSet = system.tag.queryTagHistory(paths=[sourcePath], startDate=startTime, endDate=endTime, returnFormat='Wide')
converted=system.dataset.toPyDataSet(dataSet)
dst=[destPath]*len(converted)
datetimes=[x[0] for x in converted]
Values=[x[1] for x in converted]
Quality=[192]*len(converted)
print [x[1] for x in converted[:10]]
system.tag.storeTagHistory(
historyprovider='seneca',
tagprovider='default',
path=[destPath]*len(converted),
values=Values,
qualities=[192]*len(converted),
timestamps=[x[0] for x in converted])
Here is the error I get:
File "<input>", line 23, in <module>
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:954)
at com.inductiveautomation.ignition.client.script.ClientTagUtilities.storeTagHistoryImpl(ClientTagUtilities.java:327)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.storeTagHistory(AbstractTagUtilities.java:602)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: No values provided.
What mistake am I making?
