Noexec on /tmp results in a Gateway that fails to start
Is there any way to repoint the use of /tmp for Ignition? If you are following the CIS standards, one of the rules is to set /tmp to noexec. Generally for most application you need to adjust its use of /tmp and point ti elsewhere it can write to.
I looked through the ignition.conf and didn’t see anything obvious to change. Is there anyway I can change it?
Thanks!
NFO   | jvm 1    | 2022/08/11 11:35:03 | 11:35:02,895 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data//logback.xml] at [file:/usr/local/bin/ignition/data/logback.xml]
INFO   | jvm 1    | 2022/08/11 11:35:03 | 11:35:02,959 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO   | jvm 1    | 2022/08/11 11:35:03 | 11:35:02,961 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO   | jvm 1    | 2022/08/11 11:35:03 | 11:35:02,965 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO   | jvm 1    | 2022/08/11 11:35:03 | 11:35:02,982 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO   | jvm 1    | 2022/08/11 11:35:03 | 11:35:02,989 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO   | jvm 1    | 2022/08/11 11:35:03 | Failed to load native library:sqlite-3.23.1-3a1920f6-85ef-4152-b939-495049a2eb80-libsqlitejdbc.so. osinfo: Linux/x86_64
INFO   | jvm 1    | 2022/08/11 11:35:03 | java.lang.UnsatisfiedLinkError: /tmp/sqlite-3.23.1-3a1920f6-85ef-4152-b939-495049a2eb80-libsqlitejdbc.so: /tmp/sqlite-3.23.1-3a1920f6-85ef-4152-b939-495049a2eb80-libsqlitejdbc.so: failed to map segment from shared object
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp:
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: Encountered an error running main:
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: java.lang.UnsatisfiedLinkError: 'void org.sqlite.core.NativeDB._open_utf8(byte[], int)'
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.core.NativeDB._open_utf8(Native Method)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.core.NativeDB._open(NativeDB.java:71)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.core.DB.open(DB.java:174)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.core.CoreConnection.open(CoreConnection.java:220)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.core.CoreConnection.<init>(CoreConnection.java:76)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.jdbc3.JDBC3Connection.<init>(JDBC3Connection.java:25)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.jdbc4.JDBC4Connection.<init>(JDBC4Connection.java:24)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.SQLiteConnection.<init>(SQLiteConnection.java:45)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.JDBC.createConnection(JDBC.java:114)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.SQLiteDataSource.getConnection(SQLiteDataSource.java:410)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.sqlite.SQLiteDataSource.getConnection(SQLiteDataSource.java:398)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.db.DataSourceConnectionSource.getConnection(DataSourceConnectionSource.java:62)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.db.ConnectionSourceBase.discoverConnectionProperties(ConnectionSourceBase.java:46)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.db.DataSourceConnectionSource.start(DataSourceConnectionSource.java:44)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.logging.SQLiteAppender.configureConnectionSource(SQLiteAppender.java:211)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.logging.SQLiteAppender.start(SQLiteAppender.java:252)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.action.AppenderAction.end(AppenderAction.java:90)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.spi.Interpreter.callEndAction(Interpreter.java:309)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.spi.Interpreter.endElement(Interpreter.java:193)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.spi.Interpreter.endElement(Interpreter.java:179)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.spi.EventPlayer.play(EventPlayer.java:62)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:165)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:152)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:110)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:53)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.classic.util.ContextInitializer.configureByResource(ContextInitializer.java:75)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at ch.qos.logback.classic.util.ContextInitializer.autoConfig(ContextInitializer.java:150)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.slf4j.impl.StaticLoggerBinder.init(StaticLoggerBinder.java:84)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.slf4j.impl.StaticLoggerBinder.<clinit>(StaticLoggerBinder.java:55)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.slf4j.LoggerFactory.bind(LoggerFactory.java:150)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.slf4j.LoggerFactory.performInitialization(LoggerFactory.java:124)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:412)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:357)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.ignition.common.util.LoggerEx$Builder.build(LoggerEx.java:603)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.getLogger(IgnitionGateway.java:3635)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.<init>(IgnitionGateway.java:354)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:294)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO   | jvm 1    | 2022/08/11 11:35:03 | WrapperSimpleApp Error: 	at java.base/java.lang.Thread.run(Unknown Source)
STATUS | wrapper  | 2022/08/11 11:35:05 | <-- Wrapper Stopped
yes, you can add wrapper.java.additional.XXX=-Djava.io.tmpdir=$PATH_TO_TEMP to your ignition.conf to tell java to use an alternate directory for your temp dir
set the XXX value to a unique digit
Set -Dorg.sqlite.tmpdir in ignition.conf and see if that changes anything for you.
SQLite is doing this, and it’s defaulting to the Java temp dir.
Or what @jcoffman said :stuck_out_tongue:
Hot dang you guys are quick!
Magic settings:
# grep temp data/ignition.conf
wrapper.java.additional.2=-Djava.io.tmpdir=/usr/local/bin/ignition/temp
Any reason I shouldn’t point it here? The directory already existed so I felt that was satisfactory.
I have a suspicion that the “temp” dir inside $IGNITION is not actually temporary and nothing ever cleans it up… but maybe I’m just jaded and wrong. It could very well get deleted every startup.
Sounds like Ill need to test it! Thanks as always Kevin!
For folks that are playing with containerization of ignition and the docker image this was a major headache. This java argument was how I was finally able to resolve getting the containers to start on our RHEL 8 servers with podman play kube.
