7.9.12
I’m getting some errors in the designer when I have a window open that don’t specify the component that the errors are coming from:
I know that I’m using a case statement to convert a tag value into a string, with one of the values corresponding to “Unclamping”, however there are a large number of these on the page. Also, I’d like to know why the component isn’t being specified.
How can I diagnose these?
Details:
java.lang.ClassCastException: Error trying to coerce 'unclamping' to a number.
at com.inductiveautomation.ignition.common.TypeUtilities.toNumber(TypeUtilities.java:720)
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1000)
at com.inductiveautomation.ignition.common.TypeUtilities.toInteger(TypeUtilities.java:1308)
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:993)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.setQValue(AbstractPropertyAdapter.java:218)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.setQValue(SimpleBoundTagAdapter.java:248)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:259)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.notifyTagChanged(SimpleBoundTagAdapter.java:501)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.tagChanged(SimpleBoundTagAdapter.java:490)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$TagChangeListenerProxy.tagChanged(DatasourceTagManager.java:1075)
at com.inductiveautomation.ignition.client.sqltags.impl.ChangeNotifier.run(ChangeNotifier.java:38)
at com.inductiveautomation.ignition.client.sqltags.impl.db.BatchNotifier.run(BatchNotifier.java:77)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Ignition v7.9.12 (b2019070213)
Java: Oracle Corporation 1.8.0_191
