NoSuchMethodError when trying to login into perspective session
Hi everyone
When I try to login into perspective, I get HTTP Error 500
HTTP ERROR 500 Server Error
URI: /data/perspective/login/Vis
STATUS: 500
MESSAGE: Server Error
The server log has following warning:
WARN
ServletChannel
07Feb2026 14:02:09
/data/perspective/login/Home2453
java.lang.NoSuchMethodError: 'com.inductiveautomation.ignition.gateway.auth.web.WebAuthRequestCollection com.inductiveautomation.ignition.gateway.auth.web.WebAuthRequestCollection.getOrCreate(com.inductiveautomation.ignition.gateway.dataroutes.RequestContext)'
at com.inductiveautomation.perspective.gateway.comm.Routes.login(Routes.java:1373)
at com.inductiveautomation.perspective.gateway.comm.Routes$PerspectiveRouteHandlerAdapter.handle(Routes.java:1085)
at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:355)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:117)
at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:152)
at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:40)
at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:614)
at org.eclipse.jetty.ee10.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1385)
at org.eclipse.jetty.ee10.servlet.ServletHolder.handle(ServletHolder.java:751)
at org.eclipse.jetty.ee10.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1622)
at com.inductiveautomation.catapult.filters.GatewayFilter.doFilter(GatewayFilter.java:119)
at jakarta.servlet.http.HttpFilter.doFilter(HttpFilter.java:97)
at org.eclipse.jetty.ee10.servlet.FilterHolder.doFilter(FilterHolder.java:205)
at org.eclipse.jetty.ee10.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1594)
at org.eclipse.jetty.ee10.servlet.ServletHandler$MappedServlet.handle(ServletHandler.java:1555)
at org.eclipse.jetty.ee10.servlet.ServletChannel.dispatch(ServletChannel.java:823)
at org.eclipse.jetty.ee10.servlet.ServletChannel.handle(ServletChannel.java:440)
at org.eclipse.jetty.ee10.servlet.ServletHandler.handle(ServletHandler.java:470)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:575)
at org.eclipse.jetty.ee10.servlet.SessionHandler.handle(SessionHandler.java:717)
at org.eclipse.jetty.server.handler.ContextHandler.handle(ContextHandler.java:1071)
at org.eclipse.jetty.rewrite.handler.RewriteHandler$LastRuleHandler.handle(RewriteHandler.java:159)
at org.eclipse.jetty.rewrite.handler.Rule$Handler.handle(Rule.java:108)
at org.eclipse.jetty.rewrite.handler.HeaderPatternRule$1.handle(HeaderPatternRule.java:89)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:143)
at org.eclipse.jetty.server.Handler$Sequence.handle(Handler.java:805)
at org.eclipse.jetty.server.Server.handle(Server.java:182)
at org.eclipse.jetty.server.internal.HttpChannelState$HandlerInvoker.run(HttpChannelState.java:677)
at org.eclipse.jetty.server.internal.HttpConnection.onFillable(HttpConnection.java:416)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:322)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:480)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:443)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:293)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:201)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:311)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:981)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1211)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1166)
The error appears regardless which Identity Provider I use in the Security Section in the General Project Properties.
Login into the Designer works without a problem, I can also edit perspective views and see the preview in the designer without any issue.
I am using Ignition 8.3.3 behind a traefik 3.6.7 ingress controller. Both are running in docker containers.
Thanks in advance for your help
BR
Christian
Do you somehow have a mismatched Perspective module version for the Gateway version? Can you get a screenshot of the modules page in the Gateway?
Seeing that I realized that all modules seem to be outdated which happened because I mounted the user-lib directory in docker
I removed the mount recreated the container and login works again
Seems that I’ll have to use the solution for the modules in docker from the wiki to get the MQTT-Module workiig
Thanks for the hint
BR
Christian
