Not able to lauch anything after importing gateway 8.0.10 from Linux to windows server fails
Many thanks for your help again but my issue turned out to be different to what i originally thought. After transferring the gateway I had to modify gateway xml file to set "forced secure redirect" to false and then restart ignition service. After that i am able to launch designer and client again.
the procedure was described in the post below:
I am very glad that every day i keep learning something new thanks to this forum :slight_smile:
