Hello,
I have a weird problem here. In my perspective view, I am able to pull the data to my table before 12.59 pm but not for 1 pm and after that. I have no idea what is the problem here. Have you encountered such a thing before?
My dataset has a column titled “datetime_created” and its datatype is Date
Now in my history table, I am filtering based on a start time and end time.
I do not use any format transformation for dates and I am getting this preview:
However, I get this error too when I select the desired date/time:
Conversion failed when converting date and/or time from character string.
I tried pattern transformation, it is working but it is not showing the data after I choose 1 PM and above as an end date.
Check that your date formats are the same, ive seen some weirdness when they didn’t match.
Found the issue!
The format pattern is wrong.
It should be:
yyyy-MM-dd HH:mm:ss
instead of
yyyy-MM-dd hh:mm:ss
You could simplify things by utilizing the formatted value property of your date time input, that way you don’t need any custom properties or transforms.
That’s a very good point! Thank you!!!
