I stopped ignition
Deleted all files and folders from projects folder
Cloned 10 projects
started ignition
only 4 visible in designer and ignition perspective client fails to load starting project.
Any idea why?
Example of log for one of the projects that doesn’t show in designer:
Setting LastModification to “external” on zicamarillofactory/CamarilloFactory/InspectionLine1/InspectionLine1/Big [com.inductiveautomation.perspective/views]
Thanks Jonathan. Since the projects were the same (just refreshed due to some repo issue), I thought delete and clone would work.
However, with your comment I went and looked at the gateway and found that a simple edit fixed the problem. As you can see the old project was Camel case and new one is all lowercase, and selecting right name fixed it.
