Hello All,
Currently using an Automation Direct BRX PLC and publishing data to my Chariot SCADA broker in my distributor module. I’ve been able to create a custom namespace on engine and get my tags to auto-populate. I noticed that they are all read-only though. After turning off block property changes, node commands, and device commands, they are still read only. I checked my ACL on my distributor and it is RW # as well. Everything is connected properly as well.
I tried to use the transmission module, and my folders would create, but no tags would be in them. Any push in the direction I need to go?
All help is appreciated.
Thanks!
