When using system.date.parse with formats other than the standard, it returns whatever dates it feels like, everything but what it should!
E.g.
system.date.format(
system.date.parse('20250312_120000', 'YYYYMMdd_HHmmss')
u'2024-12-29 12:00:00' (or Sun Dec 29 12:00:00 ACDT 2024)
Ok nevermind... apparently "YYYY" should be "yyyy"
Java thinks Y is "Week Year" and y is Year... good job Java for being different....
First time using Ignition
Yep, I had used 'YYYY' for years before discovering it. We're usually on shutdown between Christmas and New Year's, so it was a self inflicted bug that didn't show itself for a very... long... time.
It's funny, there are at least 4 different date format formats I've found so far in Ignition:
- Python, not that you should use its datetime objects (
%Y-%M or something)
- Java (
yyyy-MM-dd HH:mm:ss - lowercase y)
- Expression function dateFormat (
yyyy-MM-dd HH:mm:ss - lowercase y, same as Java)
- SQL (ok, not really Ignition) (
YYYY-MM-dd HH:mm:ss - normal)
- Perspective Tables (
YYYY-MM-DD HH:mm:ss - DDs)
Also:
stringFormat("%tY-%<tm-%<td %<tH:%<tM:%<tS", someDateObj)
or
stringFormat("%tF %<tT", someDateObj)
( From java.util.Formatter )
I tend to use a variant of that last, because when formatting dates, you are usually also formatting other things. And those work in Ignition's logger's .debugf(), .infof() and similar methods.
