Not Defined - Global Name
I have a Project Script where I keep getting an error when I call it from a component expression. The error states "global name not defined". Do you know what could be causing this issue?
chill_example.txt (1.3 KB)
In the future, post your code as preformatted text as it will be easier to copy/paste to show you what the problems could be.
Looking at your script, you're referring to PouringFurnaceCopy_Melting_Summary_HWS_DISA.Chill.ATAS but that's not defined anywhere in your script or passed as a parameter. If this is a tag, you'll need to use a readBlocking function to read this value before you can use it.
Edit: Or, if it's meant to be a string, then it needs to be enclosed in quotes.
Looking at the text file you provided, you will need to pass the location as a parameter.
def chillMetric(location):
    #Create Params
	    thermal_params = {"measure_loc":location}
With the runScript expression similar to:
runScript('Melting.Fitting.chillMetric', {self.view.getChild("root").custom.location})
Note that you may have to adjust the path to the property.
Don't forget the non optional poll rate param on runScript when passing arguments.
I must have overlooked the text file. See it now, but it doesn't match the screenshot.
Yeah, need to do like you said, plus add the poll rate parameter.
I am using Vision, however I have referenced it this way in the past with Perspective.
If the script is in a scripting file, you have to pass the parameters (no matter if you're using Vision or Perspective). You tagged the post as Perspective, so you got an answer using perspective.
I did it for them.
Yep, just realized that. Its actually vision.
This worked. I had to adjust the path property since this was done in vision. -Thanks
