Not the full screen
Computer resolution 1920 * 1080,It still has a white edge when running,it isn't the full screen.
In Vision Client Launcher try 'FullScreen'...
or this:
also try to reduce the width of the window from 1920 to 1831... (because your height is 1030)...
https://calculateaspectratio.com/
Also, just give up on trying to set an exact pixel size for windows.
Design your windows at approximately the aspect ratio they'll be deployed on, as small as possible. Make judicious use of anchored layouts to allow your components to resize up smoothly. Don't even try to chase the dragon of pixel-perfect ratios.
i ,see.the main windows height is 1030,when i set 950 ,it's OK,thanks
thanks
