Notes from user gateway
Hello!
In order to aply some filters on my project depending on the user logging in I would need to add some notes on each user.
To get the userName Perspective use: session.props.auth.user.userName
how to fetch the notes from User Properties?
Use the user name to call system.user.getUser(userSource, username)
You should get the notes from the return user object.
system.user.getUser() only works with Ignition User Sources, not Identity Providers. While you can use Ignition's native Identity Provider to work through a user source, external identity providers are popular.
in Ignition Vision we had access to Notes with:
import re
import app.misc
app.misc.userName = system.security.getUsername()
oUser = system.user.getUser(app.misc.strUserSource, app.misc.userName)
app.misc.userRoles = oUser.getRoles()
try:
	cNotes = oUser.getOrDefault(oUser.Notes)
	if (cNotes == "") or (cNotes == None):
		cNotes = "level:0;groups:0;zones:8;mainGroup:-1"
except:
	cNotes = "level:0;groups:0;zones:8"
if ('Administrador' in app.misc.userRoles) or ('Direccion' in app.misc.userRoles):
	cNotes = "access:9999999999;zones:0,1,2,3,4,5,6"
In ignition perspective can have access to notes??? with:
	from com.inductiveautomation.ignition.common import BasicDataset
	userSource = "default"
	userName = session.props.auth.user.userName
	try:
	    if userName:
	        user = system.user.getUser(userSource, userName)
	        if user is not None:
	            notes = user.get("notes")
	            if notes is None:
	                notes = "No notes available for this user."
	        else:
	            notes = "User not found."
	        session.custom.userNotes = notes
	    else:
	        session.custom.userNotes = "User not logged in."
or should I try using ?
If you are using Ignition's internal IdP, you can use system.user.getUser(). If using any other IdP, you must work with the data the IdP supplied. In recent versions of Ignition the complete data packet is supplied to a session property, but you will probably want to use attribute mapping:
Right now I using Ignition Idp. But for some reason I don´t reach notes with my fetch:
	try:
	    if userName:
	            if notes is None:
	        else:
	    else:
Ok, now working after restart the gateway, thank you!
