Hi everyone,
I'm using the Voice and notification modules to create a pipeline. If all the roosters fails to pick up the calls it stops. Is there a way to have it loop until someone picks up?
Will the Notification-block change the pipelines properties, so I can use a script after the Notification to check if it should restart, and loop the message back to the input?
1 st, no answer, 2nd, no answer, 3rd, no answer -> try 1 st again and so on.
Thanks in advance.
