We are installing the Notification module using an Airlink RV50.
How do you log into the RV50 via SSH?
PS - We have been using Article #360047613111, Sierra Wireless Airlink RV50 setup guide from Inductive Automation for setup and install.
Hi @paulm1,
The Sierra Wireless Airlink RV50 Setup Guide contains some information on this in "5. Configure SSH Interface."
The configuration recommended by Inductive Automation suggests SSH in preference to Telnet.
To SSH into the router from systems that do not have built-in SSH functionality (for example, from Windows systems), use PuTTY or some other SSH Client. See Ethernet section for IP and login credentials.
Services > Telnet / SSH
Make the following changes in the Telnet/SSH section of the Services tab:
- Remote Login Server Mode: SSH
- Default Telnet User: None
Sierra Wireless also has a forum here for any RV50 device-specific questions or concerns on this SSH setup beyond our guide.
