Now() is returning 1905
Do to an odd situation that store and forward seemed to have "locked up", I am looking to using the ignition now() function to be saved to the db. Seems pretty straight forward I put the below in an express, but instead of the current date and time I am getting 1905-07-17 00:00:00.000. Any ideas?
dateFormat(now(), "yyyy-MM-dd HH:mm:ss")
Where are you seeing this? In the expression editor Binding Preview? Is the clock correct on the PC?
Are you secretly (or not so secretly) a time traveller?
1905 is strange as it's prior to unix epoch... Try capital YYYY. Edit: the manual says lower-case
Clock is correct. Im not so not sure what you mean Binding Preview Im new. This is just a simple transaction with a triggered expression.
Nvm, thanks guys for trying. I accidentally left the type as int, now it works
Damn, so not a time traveller :unamused: I thought I was going to provide you the stocks charts and we could have laughed at that Bozos guy's pittance. Next time perhaps
On the bright side, once you've gotten your tailfeathers plucked by something like that, it's a lot easier to troubleshoot the next time around.
