Null Pointer Exception/Error on Window Activated / Opened
Using this code to load an image from BLOB in the database into the icon field of a label.
When the code is attached to a button, it works fine, but I need the code to load the image as soon as the popup window is opened. I’m trying to add the code when the window is activated / opened, but get a null exception:
The Code in WindowActivated/WindowOpened
from javax.swing import ImageIcon
from java.io import ByteArrayInputStream
from javax.imageio import ImageIO
from java.awt import Image
from java.net import URL
from java.io import File
image = system.db.runScalarPrepQuery("SELECT image FROM Products where id=15757")
bais = ByteArrayInputStream(image)
bImageFromConvert = ImageIO.read(bais)
lbl3 = event.source.parent.getComponent('Label 29')
boundWidth = lbl3.width
boundHeight = lbl3.height
originalWidth = bImageFromConvert.width
originalHeight = bImageFromConvert.height
newWidth = originalWidth
newHeight = originalHeight
if originalWidth > boundWidth:
   newWidth = boundWidth
   newHeight = (newWidth * originalHeight) / originalWidth
if newHeight > boundHeight:
   newHeight = boundHeight
   newWidth = (newHeight * originalWidth) / originalHeight
scaledImage = bImageFromConvert.getScaledInstance(newWidth,newHeight,Image.SCALE_SMOOTH)
lbl3.setIcon(ImageIcon(scaledImage))
The Error in designer:
  File "<event:internalFrameOpened>", line 10, in <module>
	at org.python.core.PyJavaType.wrapJavaObject(PyJavaType.java:90)
	at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.<init>(PyComponentWrapper.java:57)
	at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.__findattr_ex__(PyComponentWrapper.java:94)
	at org.python.core.PyObject.__getattr__(PyObject.java:1025)
	at org.python.pycode._pyx29.f$0(<event:internalFrameOpened>:24)
	at org.python.pycode._pyx29.call_function(<event:internalFrameOpened>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.Py.runCode(Py.java:1614)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:770)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:200)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:291)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy60.internalFrameOpened(Unknown Source)
	at java.desktop/javax.swing.JInternalFrame.fireInternalFrameEvent(Unknown Source)
	at java.desktop/javax.swing.JInternalFrame.show(Unknown Source)
	at java.desktop/java.awt.Component.show(Unknown Source)
	at java.desktop/java.awt.Component.setVisible(Unknown Source)
	at java.desktop/javax.swing.JComponent.setVisible(Unknown Source)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3514)
	at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:197)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.lambda$openWindowImpl$5(NavUtilities.java:393)
	at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:808)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:336)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:326)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:143)
java.lang.NullPointerException: java.lang.NullPointerException
	at org.python.core.Py.JavaError(Py.java:552)
	at org.python.core.PyTableCode.call(PyTableCode.java:180)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:519)
	at org.python.core.PyObject.__call__(PyObject.java:480)
	at org.python.core.PyObject.__call__(PyObject.java:484)
	at org.python.pycode._pyx5.f$0(<event:actionPerformed>:7)
	at org.python.pycode._pyx5.call_function(<event:actionPerformed>)
	at com.sun.proxy.$Proxy58.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.NullPointerException
	... 72 more
Ignition v8.0.8 (b2020021111)
Java: Azul Systems, Inc. 11.0.5
Error in vision:
TypeError: getComponent(): 1st arg can't be coerced to int
event.source in a window event is the window. In your button events it is the button. You’ll need something like:
lbl3 = event.source.rootContainer.getComponent('Label 29')
Note: please edit your post to properly delimit your pasted code and exception text. Use three backticks together above and below the pasted material so it formats properly. It should look like this in the forum’s editor pane:
pasted material
Seems so obvious now, worked like a charm. Thanks! I also edited my original post, to have proper formatting.
Thanks again.
