Null text / Bad stale
try({../Table.props.selection.data[0].Name}, " ")
I have this code bound to a text prop on a label in perspective. After moving the view into an embedded view, the label starts with a text null found and bad quality error on it. It is an eye sore, what is the reason?
The try() function substitutes an alternative when a nested expression produces an error, but a null is not an error. And, it so happens, that Perspective property names/indices/object keys that don't exist don't throw an error. They return null, instead.
You likely need to use the coalesce() function instead of try(), or perhaps use both of them.
try(coalesce({../Table.props.selection.data[0].Name}, " "), " ")
I am not sure if this is the proper way to use coalesce with a try, but it seems to have worked!
