NullPointerException: Power Table Cell Edit with DB Update
I have a power table that uses the isCellEditable and onCellEdit extensions. If the value in the column is 0, then it is editable. On double click, the user alters the value which is written back to the db, nothing that complicated.
	data = self.data
	ndx = data.getValueAt(rowIndex,'ndx')
	system.db.runNamedQuery('updateZeroProg',{'code':newValue,'ndx':ndx})
	system.db.refresh(self,"data")
isCellEditable()
	if colName == 'Code' and value == 0:
		return True
When I test the cell edit, the db updates and the table shows the correct data, but I get the following error below, any ideas?
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
	at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Model.isCellEditable(VisionAdvancedTable.java:1717)
	at com.jidesoft.grid.TableModelWrapperImpl.isCellEditable(Unknown Source)
	at com.jidesoft.grid.DefaultTableModelWrapper.isCellEditable(Unknown Source)
	at javax.swing.JTable.isCellEditable(Unknown Source)
	at javax.swing.table.DefaultTableCellRenderer.getTableCellRendererComponent(Unknown Source)
	at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Renderer.getTableCellRendererComponent(VisionAdvancedTable.java:1438)
	at com.jidesoft.grid.JideTable.prepareRenderer(Unknown Source)
	at com.jidesoft.grid.CellStyleTable.prepareRenderer(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paintCell(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.a(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paint(Unknown Source)
	at com.jidesoft.plaf.basic.BasicCellSpanTableUIDelegate.paint(Unknown Source)
	at com.jidesoft.plaf.basic.BasicCellSpanTableUI.paint(Unknown Source)
	at javax.swing.plaf.ComponentUI.update(Unknown Source)
	at javax.swing.JComponent.paintComponent(Unknown Source)
	at com.jidesoft.grid.CellStyleTable.paintComponent(Unknown Source)
	at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$4.paintComponent(VisionAdvancedTable.java:259)
	at javax.swing.JComponent.paint(Unknown Source)
	at javax.swing.JComponent.paintChildren(Unknown Source)
	at javax.swing.JViewport.paint(Unknown Source)
	at com.inductiveautomation.vision.api.client.components.model.AbstractVisionScrollPane$PrintableViewport.paint(AbstractVisionScrollPane.java:175)
	at com.inductiveautomation.vision.api.client.components.model.AbstractVisionScrollPane.paintChildren(AbstractVisionScrollPane.java:377)
	at com.inductiveautomation.vision.api.client.components.model.AbstractVisionScrollPane.paintComponent(AbstractVisionScrollPane.java:372)
	at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.paintChildren(AbstractVisionPanel.java:279)
	at javax.swing.JComponent.paintToOffscreen(Unknown Source)
	at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
	at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
	at javax.swing.RepaintManager.paint(Unknown Source)
	at javax.swing.JComponent._paintImmediately(Unknown Source)
	at javax.swing.JComponent.paintImmediately(Unknown Source)
	at javax.swing.RepaintManager$4.run(Unknown Source)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
	at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
	at javax.swing.RepaintManager.prePaintDirtyRegions(Unknown Source)
	at javax.swing.RepaintManager.access$1200(Unknown Source)
	at javax.swing.RepaintManager$ProcessingRunnable.run(Unknown Source)
	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at javax.swing.JLayeredPane.paint(Unknown Source)
	at com.inductiveautomation.ignition.designer.designable.DesignPanel$DesignableContainerLayer.paintChildren(DesignPanel.java:1169)
What happens if you put an ‘else return False’ in the isCellEdited script?
Is it needed? Beats me, but it seems to me that with nothing to return if false, then that could be troublesome.
Yep that was it. Thanks!
