NullPointerException using getSelectedPaths()
Hi Guys,
We use getSelectedPaths function in our project but in some situations the function thrown java NullPointerException error
We use the tree view component in our project, as an special feature we want to display some options when a “folder” (not a node) is selected, in order to do that we have an script that use getSelectedPaths to know the folder’s name when the selectedItem is -1.
This is the part of the code where the error happens:
[code]if event.clickCount > 0:
if event.source.selectedItem == -1:
aux=muestra_equipo(event)
def muestra_equipo(event):
nombreEquipo = event.source.getSelectedPaths()[0]
event.source.parent.parent.getComponent(‘Equipo’).visible = 1
return nombreEquipo[/code]
The error says that the problem occurs where the code calls event.source.getSelectedPaths()[0]
The process works fine but randomly we get a java NullPointerException error fired by getSelectedPaths function. The error always happens when a “folder” is clicked but never when a node is.
This is the entire error:
[quote]Traceback (most recent call last):
File “event:mouseClicked”, line 122, in
File “event:mouseClicked”, line 13, in muestra_equipo
at com.inductiveautomation.factorypmi.application.components.PMITreeView.getSelectedPaths(PMITreeView.java:783)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
java.lang.NullPointerException: java.lang.NullPointerException
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at org.python.core.PyMethod.__call__(PyMethod.java:109)
at org.python.pycode._pyx6.muestra_equipo$1(<event:mouseClicked>:15)
at org.python.pycode._pyx6.call_function(<event:mouseClicked>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:317)
at org.python.pycode._pyx6.f$0(<event:mouseClicked>:129)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:554)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy14.mouseClicked(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.util.EventDelegateDispatcher$MouseEventDispatcher.mouseClicked(EventDelegateDispatcher.java:97)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:270)
at java.awt.Component.processMouseEvent(Component.java:6519)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3320)
at java.awt.Component.processEvent(Component.java:6281)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4872)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4698)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.lang.NullPointerException
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
… 52 more
Ignition v7.6.6 (b2014040112)
Java: Oracle Corporation 1.7.0_71[/quote]
System details:
Ignition version: 7.6.6 (b2014040112) 64bit
OS: Linux Debian 7.0
Have you seen this problem before? Do you have a solution for it?
Regards,
Manuel.
