I’ve recently upgraded from 7.9 to 8.1.17. I’m checking over some Vision projects and every time I open a new project, I’m getting a NullPointerException. I also get an NPE when closing the Designer and it doesn’t actually close. I have to actually use the Task Manager to kill the Java process.
I don’t see anything in the release notes for 8.1.18 or .19 that seems relevant, so I’m not sure if upgrading will help.
This is the error when trying to open a new project:
java.lang.NullPointerException
at com.inductiveautomation.ignition.client.model.AbstractClientContext.shutdown(AbstractClientContext.java:102)
at com.inductiveautomation.ignition.designer.DesignerContextImpl.shutdown(DesignerContextImpl.java:450)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.cleanup(IgnitionDesigner.java:933)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:944)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:911)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$1.openProject(IgnitionDesigner.java:2200)
at com.inductiveautomation.ignition.designer.ProjectDialog.lambda$openProject$4(ProjectDialog.java:156)
Ignition v8.1.17 (b2022051210)
Java: Azul Systems, Inc. 11.0.15
And here is the error from the console when I try to close the Designer:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.IgnitionDesigner.shutdown(IgnitionDesigner.java:509)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleExit(IgnitionDesigner.java:3068)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$12.actionPerformed(IgnitionDesigner.java:2425)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
