I did just duplicated my 7.9.10 server for a upgrade to 8.0 test. Seemed to fail in the same matter. Only grey screen when launcing vision clients.
Console:
Exception in thread “AWT-EventQueue-0” java.lang.NullPointerException: WindowInfo for window com.inductiveautomation.vision/windows/PerfectChat was null.
at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowInfo(WindowCache.java:182)
at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowInfo(WindowCache.java:145)
at com.inductiveautomation.factorypmi.application.model.WindowCache.lambda$getStartupWindows$4(WindowCache.java:487)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.factorypmi.application.model.WindowCache.getStartupWindows(WindowCache.java:491)
at com.inductiveautomation.factorypmi.application.FPMIApp.startup(FPMIApp.java:496)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel.lambda$null$4(ClientPanel.java:663)
I tested with the latest build, and I can say that I got better results. I can see our main start up window, but our navigation window is nowhere to find. 7.9.10 project restored.
We have this same issue on a old project that can be loaded either in 7.6, 7.7 and 7.9 without issues. When trying to run it in 8 we receive the following error
09:39:35.398 [Thread-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Updated login state. Logged in? true, Username: admin, Roles: [Administrator], Security Zones: null
09:39:35.450 [ClientExecEngine-1] INFO tags.subscriptions - Changing connected quality to ‘Good’
09:39:35.450 [Thread-4] INFO tags.manager.gwinterface - Tag poll rate changed to 250 ms
09:39:37.116 [Thread-4] INFO com.inductiveautomation.reporting.client.ReportingClientHook - Starting up Reporting Module. Mode: Activated
09:39:37.162 [Thread-4] INFO com.ipg.sentinel.client.hooks.IPGClientHook - IPGClientHook: adding BACKSTAFF to ScriptManager in Client Hook
09:39:37.192 [Thread-4] INFO com.ipg.sentinel.client.hooks.IPGClientHook - IPGClientHook: BACKSTAFF added to ScriptManager in Client Hook
09:39:38.006 [AWT-EventQueue-0] INFO vision.App - Starting Up…
Exception in thread “AWT-EventQueue-0” java.lang.NullPointerException: WindowInfo for window com.inductiveautomation.vision/windows/Header was null.
at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowInfo(WindowCache.java:183)
at com.inductiveautomation.factorypmi.application.model.WindowCache.lambda$getStartupWindows$4(WindowCache.java:488)
at com.inductiveautomation.factorypmi.application.model.WindowCache.getStartupWindows(WindowCache.java:492)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel.lambda$null$3(ClientPanel.java:681)
The mentioned window “Header” is marked as Open or Startup. One thing to mention is Header window is contained under the sctructure Vision\Windows\Header\Header (that is, there’s a parent folder named Header which contains also other window related to header). The rest of windows in the project are organized the same way, under folders, to allow a better organization for all the windows in the project and that hasn’t been a problem in previous versions of Ignition. Is that a problem in Ignition 8?
Could you please try a newer build? This looks similar to a different issue we fixed over the weekend.
If you have a Gateway backup from before this occurred, please upgrade and then restore from backup.
Yes. Going forward, you'll want to stick close to the most recent build; we're introducing fixes and new features at a pace that make a month-old build almost impossible to validate against. In your case, this thread claims that a fix has already been put in place:
