Number format is too long
SnĂ­mek obrazovky 2022-04-21 154640
Hello,
So I have a problem with TimeSeriesChart and the infobox in version 8.1.9. I use perspective and my data is as on the picture. From DB I get a normal point number but in the infobox, I have so long number.
I tried the number format change and it was without effect.
Can you help me, please?
Thank you
my data:
InfoBox
Please find the chart in the Project Browser, right-click, copy and paste the JSON code in here. Then select it and press the </> code formatting button before posting. That way we can reproduce the problem and maybe find the problem.
Ok, I tried it.
    "type": "ia.chart.timeseries",
    "version": 0,
    "props": {
      "series": [
          "name": "Boiler"
      "plots": [
          "trends": [
              "axis": "Foukaná Teplota",
              "baselines": [],
              "breakLine": true,
              "columns": [],
              "interpolation": "curveLinear",
              "radius": 2,
              "series": "Boiler",
              "stack": true,
              "type": "line",
              "visible": true
          "axes": [
              "alignment": "left",
              "label": {
                "font": {
                  "color": "",
                  "size": 10
                "offset": 0,
                "style": {
                  "classes": ""
                "text": "",
                "visible": true
              "max": 40,
              "min": -20,
              "name": "Foukaná Teplota",
              "style": {
                "classes": ""
              "tick": {
                "color": "",
                "label": {
                  "font": {
                    "color": "",
                    "size": 10
                  "style": {
                    "classes": ""
                "style": {
                  "classes": ""
              "width": 50
          "markers": []
      "timeAxis": {
        "tickCount": 10
      "timeRange": {
        "timeFormat": "HH:mm:ss"
      "xTrace": {
        "infoBox": {
          "width": 270,
          "dateFormat": "MM-DD-YYYY",
          "timeFormat": "HH:mm:ss",
          "dataFormat": "0,0"
      "legend": {
        "visible": true,
        "position": "top"
      "defaultStyles": {
        "colors": [
          "#00D900",
          "#FF0000",
          "#555555",
          "#0000FF",
          "#00FFFF",
          "#FF00FF"
        "muted": {
          "stroke": {
            "opacity": 0.1
          "fill": {
            "opacity": 0.1
    "meta": {
      "name": "TimeSeriesChart"
    "position": {
      "x": 33,
      "y": 154,
      "height": 401,
      "width": 1073
    "custom": {},
    "propConfig": {
      "props.series[0].data": {
        "binding": {
          "config": {
            "aggregate": "LastValue",
            "avoidScanClassValidation": true,
            "dateRange": {
              "mostRecent": "10",
              "mostRecentUnits": "HOUR"
            "ignoreBadQuality": false,
            "polling": {
              "enabled": false,
              "rate": "30"
            "preventInterpolation": false,
            "returnFormat": "Wide",
            "returnSize": {
              "numRows": "250",
              "type": "FIXED"
            "tags": [
                "alias": "Foukaná Teplota",
                "path": "[OPA]VZT/Machine/Temp/BlownTemp"
                "alias": "OdtahovanĂ˝ Vzduch",
                "path": "[OPA]VZT/Machine/Temp/ExhaustTemp"
                "alias": "Nastavená Teplota",
                "path": "[OPA]VZT/Machine/Temp/SetTemp"
                "alias": "Teplota T5",
                "path": "[OPA]VZT/Machine/Temp/TempT5"
                "path": "[OPA]VZT/Machine/Temp/TempTherms"
                "alias": "Teplota Venku",
                "path": "[OPA]VZT/Machine/Temp/OutTempMem"
            "valueFormat": "DATASET"
          "type": "tag-history"
Thanks for the chart JSON.
I tried to reproduce the problem but it looks OK for me.
Unfortunately your pasted chart only has the binding. We need the some actual data to reproduce the problem. Can you right-click on series.data.0 and post that too?
I wonder if the problem is because you are using , in your number format?
Hi
I apologize for the delay, I was sick and then I was out of the office. I’m trying to solve my problem and I found that this view is only on the website. In Ignition Designer, everything is fine I’m sending a picture.
    "ds",
    192,
    1652683805028
  "$columns": [
      "name": "t_stamp",
      "type": "Date",
      "data": [
        1652424240000,
        1652424240000,
        1652427840000,
        1652427840000,
        1652431440000,
        1652431440000,
        1652435040000,
        1652435040000,
        1652438640000,
        1652438640000,
        1652442240000,
        1652442240000,
        1652445840000,
        1652445840000,
        1652449440000,
        1652449440000,
        1652453040000,
        1652453040000,
        1652456640000,
        1652456640000,
        1652460240000,
        1652460240000,
        1652463840000,
        1652463840000,
        1652467440000,
        1652467440000,
        1652471040000,
        1652471040000,
        1652474640000,
        1652474640000,
        1652478240000,
        1652478240000,
        1652481840000,
        1652481840000,
        1652485440000,
        1652485440000,
        1652489040000,
        1652489040000,
        1652492640000,
        1652492640000,
        1652496240000,
        1652496240000,
        1652499840000,
        1652499840000,
        1652503440000,
        1652503440000,
        1652507040000,
        1652507040000,
        1652510640000,
        1652514240000,
        1652517840000,
        1652521440000,
        1652525040000,
        1652528640000,
        1652528640000,
        1652532240000,
        1652532240000,
        1652535840000,
        1652535840000,
        1652539440000,
        1652539440000,
        1652543040000,
        1652543040000,
        1652546640000,
        1652546640000,
        1652550240000,
        1652550240000,
        1652553840000,
        1652553840000,
        1652557440000,
        1652557440000,
        1652561040000,
        1652561040000,
        1652564640000,
        1652564640000,
        1652568240000,
        1652568240000,
        1652571840000,
        1652571840000,
        1652575440000,
        1652575440000,
        1652579040000,
        1652579040000,
        1652582640000,
        1652582640000,
        1652586240000,
        1652586240000,
        1652589840000,
        1652589840000,
        1652593440000,
        1652593440000,
        1652597040000,
        1652597040000,
        1652600640000,
        1652600640000,
        1652604240000,
        1652604240000,
        1652607840000,
        1652607840000,
        1652611440000,
        1652611440000,
        1652615040000,
        1652615040000,
        1652618640000,
        1652618640000,
        1652622240000,
        1652622240000,
        1652625840000,
        1652625840000,
        1652629440000,
        1652629440000,
        1652633040000,
        1652633040000,
        1652636640000,
        1652636640000,
        1652640240000,
        1652640240000,
        1652643840000,
        1652643840000,
        1652647440000,
        1652647440000,
        1652651040000,
        1652651040000,
        1652654640000,
        1652654640000,
        1652658240000,
        1652658240000,
        1652661840000,
        1652661840000,
        1652665440000,
        1652665440000,
        1652669040000,
        1652669040000,
        1652672640000,
        1652672640000,
        1652676240000,
        1652676240000,
        1652679840000,
        1652679840000,
        1652683440000,
        1652683440000
      "type": "Double",
      "data": [
        17.0,
        18.200000762939453,
        19.299999237060547,
        16.799999237060547,
        16.399999618530273,
        17.0,
        17.200000762939453,
        18.200000762939453,
        18.299999237060547,
        17.700000762939453,
        18.5,
        18.200000762939453,
        18.899999618530273,
        18.600000381469727,
        18.799999237060547,
        18.899999618530273,
        18.600000381469727,
        18.700000762939453,
        18.399999618530273,
        17.700000762939453,
        16.0,
        18.799999237060547,
        18.200000762939453,
        17.100000381469727,
        16.600000381469727,
        16.0,
        16.100000381469727,
        15.5,
        15.0,
        14.5,
        13.600000381469727,
        13.300000190734863,
        12.899999618530273,
        12.399999618530273,
        11.899999618530273,
        11.800000190734863,
        10.300000190734863,
        11.0,
        9.699999809265137,
        9.5,
        9.100000381469727,
        8.600000381469727,
        8.600000381469727,
        9.100000381469727,
        10.100000381469727,
        12.300000190734863,
        12.399999618530273,
        12.399999618530273,
        15.448651000980135,
        17.1178370488694,
        18.787023096758666,
        20.456209144647932,
        22.100000381469727,
        16.700000762939453,
        16.899999618530273,
        16.899999618530273,
        17.299999237060547,
        17.299999237060547,
        16.700000762939453,
        15.0,
        15.199999809265137,
        15.0,
        14.699999809265137,
        14.0,
        18.399999618530273,
        17.700000762939453,
        17.100000381469727,
        16.799999237060547,
        15.899999618530273,
        15.5,
        15.100000381469727,
        15.5,
        13.300000190734863,
        12.699999809265137,
        11.5,
        11.399999618530273,
        10.800000190734863,
        10.5,
        9.899999618530273,
        9.899999618530273,
        9.300000190734863,
        9.100000381469727,
        12.300000190734863,
        12.199999809265137,
        12.100000381469727,
        12.199999809265137,
        12.899999618530273,
        13.300000190734863,
        13.800000190734863,
        14.300000190734863,
        15.600000381469727,
        15.300000190734863,
        16.100000381469727,
        16.299999237060547,
        17.399999618530273,
        17.399999618530273,
        18.0,
        18.5,
        17.899999618530273,
        19.0,
        19.200000762939453,
        14.399999618530273,
        14.199999809265137,
        14.800000190734863,
        15.100000381469727,
        15.0,
        14.899999618530273,
        15.300000190734863,
        15.199999809265137,
        14.699999809265137,
        15.100000381469727,
        15.0,
        14.5,
        14.899999618530273,
        18.600000381469727,
        17.399999618530273,
        16.600000381469727,
        16.399999618530273,
        15.0,
        14.5,
        14.300000190734863,
        13.899999618530273,
        13.399999618530273,
        13.399999618530273,
        12.600000381469727,
        11.899999618530273,
        11.800000190734863,
        11.199999809265137,
        15.899999618530273,
        16.100000381469727,
        15.600000381469727,
        15.5,
        15.800000190734863,
        15.800000190734863,
        16.600000381469727,
        17.0,
        18.299999237060547,
        18.700000762939453,
        15.300000190734863,
        16.399999618530273,
        16.399999618530273
      "name": "OdtahovanĂ˝ Vzduch",
      "type": "Double",
      "data": [
        25.200000762939453,
        26.200000762939453,
        26.799999237060547,
        27.0,
        26.899999618530273,
        27.200000762939453,
        27.100000381469727,
        27.5,
        27.799999237060547,
        27.799999237060547,
        28.0,
        28.100000381469727,
        28.399999618530273,
        28.600000381469727,
        28.700000762939453,
        28.899999618530273,
        29.0,
        28.899999618530273,
        29.0,
        28.899999618530273,
        28.799999237060547,
        28.200000762939453,
        28.299999237060547,
        28.0,
        27.799999237060547,
        27.0,
        26.899999618530273,
        26.600000381469727,
        26.600000381469727,
        26.299999237060547,
        26.0,
        25.600000381469727,
        25.399999618530273,
        25.200000762939453,
        25.100000381469727,
        24.600000381469727,
        24.399999618530273,
        24.0,
        23.700000762939453,
        23.5,
        23.299999237060547,
        22.899999618530273,
        22.5,
        21.899999618530273,
        21.700000762939453,
        22.0,
        22.65771699099939,
        22.65771699099939,
        23.32821376548499,
        23.99871053997059,
        24.669207314456187,
        25.339704088941783,
        26.0,
        25.799999237060547,
        25.399999618530273,
        25.100000381469727,
        24.899999618530273,
        24.899999618530273,
        24.700000762939453,
        24.5,
        23.899999618530273,
        23.899999618530273,
        23.399999618530273,
        23.200000762939453,
        23.700000762939453,
        23.899999618530273,
        23.700000762939453,
        23.600000381469727,
        23.299999237060547,
        23.100000381469727,
        22.600000381469727,
        22.399999618530273,
        21.700000762939453,
        21.299999237060547,
        20.899999618530273,
        20.600000381469727,
        20.200000762939453,
        20.100000381469727,
        19.700000762939453,
        19.5,
        19.100000381469727,
        19.0,
        19.299999237060547,
        19.399999618530273,
        19.399999618530273,
        19.399999618530273,
        19.5,
        19.5,
        20.0,
        20.399999618530273,
        20.600000381469727,
        20.799999237060547,
        21.100000381469727,
        21.399999618530273,
        21.700000762939453,
        21.899999618530273,
        22.299999237060547,
        22.5,
        22.700000762939453,
        22.899999618530273,
        23.100000381469727,
        23.0,
        22.299999237060547,
        22.200000762939453,
        22.299999237060547,
        22.299999237060547,
        22.299999237060547,
        22.299999237060547,
        22.299999237060547,
        22.299999237060547,
        22.200000762939453,
        22.200000762939453,
        22.0,
        21.899999618530273,
        22.600000381469727,
        22.700000762939453,
        22.899999618530273,
        22.899999618530273,
        22.799999237060547,
        22.899999618530273,
        23.0,
        23.100000381469727,
        23.299999237060547,
        23.200000762939453,
        23.100000381469727,
        23.100000381469727,
        22.899999618530273,
        22.899999618530273,
        22.700000762939453,
        23.5,
        23.899999618530273,
        23.899999618530273,
        23.700000762939453,
        23.899999618530273,
        24.200000762939453,
        24.200000762939453,
        25.0,
        25.100000381469727,
        24.700000762939453,
        24.899999618530273,
        24.899999618530273
      "name": "Nastavená Teplota",
      "type": "Double",
      "data": [
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        14.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0,
        20.0
      "name": "Teplota T5",
      "type": "Double",
      "data": [
        28.200000762939453,
        28.899999618530273,
        29.100000381469727,
        30.0,
        29.899999618530273,
        30.299999237060547,
        30.399999618530273,
        31.299999237060547,
        31.299999237060547,
        31.399999618530273,
        31.700000762939453,
        31.799999237060547,
        32.099998474121094,
        32.20000076293945,
        32.400001525878906,
        32.29999923706055,
        32.5,
        32.400001525878906,
        32.400001525878906,
        32.099998474121094,
        31.899999618530273,
        31.399999618530273,
        31.399999618530273,
        30.799999237060547,
        30.600000381469727,
        30.100000381469727,
        29.700000762939453,
        29.600000381469727,
        29.299999237060547,
        29.0,
        28.700000762939453,
        28.299999237060547,
        28.100000381469727,
        27.799999237060547,
        27.799999237060547,
        27.299999237060547,
        27.100000381469727,
        26.899999618530273,
        26.600000381469727,
        26.200000762939453,
        26.0,
        25.5,
        24.899999618530273,
        23.600000381469727,
        23.200000762939453,
        23.100000381469727,
        23.299999237060547,
        23.299999237060547,
        24.084297563446807,
        24.464670003964144,
        24.84504244448148,
        25.225414884998816,
        25.600000381469727,
        26.200000762939453,
        25.799999237060547,
        25.600000381469727,
        25.600000381469727,
        25.5,
        25.299999237060547,
        25.100000381469727,
        24.5,
        24.200000762939453,
        23.799999237060547,
        23.5,
        23.799999237060547,
        23.899999618530273,
        23.600000381469727,
        23.399999618530273,
        23.100000381469727,
        22.700000762939453,
        22.5,
        22.200000762939453,
        21.600000381469727,
        21.5,
        20.899999618530273,
        20.600000381469727,
        20.399999618530273,
        20.0,
        19.899999618530273,
        19.5,
        19.100000381469727,
        18.799999237060547,
        18.899999618530273,
        19.0,
        19.0,
        18.799999237060547,
        18.899999618530273,
        19.100000381469727,
        19.399999618530273,
        19.700000762939453,
        20.200000762939453,
        20.399999618530273,
        20.700000762939453,
        21.299999237060547,
        21.5,
        21.799999237060547,
        22.399999618530273,
        22.5,
        22.799999237060547,
        23.100000381469727,
        23.299999237060547,
        22.799999237060547,
        22.700000762939453,
        22.5,
        22.600000381469727,
        22.600000381469727,
        22.600000381469727,
        22.5,
        22.600000381469727,
        22.5,
        22.299999237060547,
        22.299999237060547,
        22.100000381469727,
        22.100000381469727,
        22.700000762939453,
        23.5,
        24.100000381469727,
        24.600000381469727,
        25.100000381469727,
        25.5,
        25.799999237060547,
        25.700000762939453,
        25.899999618530273,
        26.0,
        26.0,
        26.100000381469727,
        26.0,
        25.899999618530273,
        25.799999237060547,
        26.5,
        26.600000381469727,
        26.700000762939453,
        26.899999618530273,
        26.799999237060547,
        27.299999237060547,
        27.299999237060547,
        28.0,
        28.0,
        28.0,
        28.100000381469727,
        28.100000381469727
      "name": "Teplota termostat",
      "type": "Double",
      "data": [
        19.100000381469727,
        20.100000381469727,
        21.299999237060547,
        22.700000762939453,
        22.700000762939453,
        23.5,
        23.600000381469727,
        25.700000762939453,
        25.299999237060547,
        23.799999237060547,
        25.0,
        24.600000381469727,
        25.399999618530273,
        25.0,
        25.299999237060547,
        24.899999618530273,
        25.0,
        24.700000762939453,
        24.600000381469727,
        23.899999618530273,
        23.700000762939453,
        21.100000381469727,
        20.299999237060547,
        18.5,
        17.700000762939453,
        16.700000762939453,
        16.200000762939453,
        15.5,
        15.100000381469727,
        14.399999618530273,
        13.699999809265137,
        12.899999618530273,
        12.399999618530273,
        12.0,
        11.199999809265137,
        11.0,
        9.800000190734863,
        10.100000381469727,
        9.0,
        8.699999809265137,
        8.399999618530273,
        7.800000190734863,
        8.0,
        8.699999809265137,
        10.0,
        13.699999809265137,
        14.100000381469727,
        14.100000381469727,
        16.580351455192144,
        18.01572279568137,
        19.451094136170596,
        20.88646547665982,
        22.299999237060547,
        22.399999618530273,
        22.100000381469727,
        22.5,
        22.899999618530273,
        23.299999237060547,
        23.100000381469727,
        23.299999237060547,
        23.0,
        22.799999237060547,
        22.399999618530273,
        21.899999618530273,
        20.299999237060547,
        19.600000381469727,
        18.600000381469727,
        18.0,
        16.799999237060547,
        16.399999618530273,
        15.399999618530273,
        15.100000381469727,
        13.199999809265137,
        12.5,
        11.300000190734863,
        11.100000381469727,
        10.199999809265137,
        10.0,
        9.5,
        9.300000190734863,
        8.5,
        8.399999618530273,
        7.900000095367432,
        7.900000095367432,
        7.699999809265137,
        8.100000381469727,
        9.699999809265137,
        10.5,
        12.699999809265137,
        14.100000381469727,
        16.399999618530273,
        17.299999237060547,
        19.299999237060547,
        19.0,
        19.700000762939453,
        19.700000762939453,
        20.5,
        21.200000762939453,
        20.200000762939453,
        21.399999618530273,
        21.899999618530273,
        21.799999237060547,
        21.899999618530273,
        22.200000762939453,
        22.5,
        22.600000381469727,
        22.200000762939453,
        22.399999618530273,
        22.600000381469727,
        22.600000381469727,
        22.299999237060547,
        23.299999237060547,
        22.100000381469727,
        20.799999237060547,
        19.399999618530273,
        18.899999618530273,
        17.0,
        16.399999618530273,
        15.699999809265137,
        15.100000381469727,
        14.300000190734863,
        14.100000381469727,
        13.300000190734863,
        12.899999618530273,
        12.5,
        11.699999809265137,
        11.300000190734863,
        10.899999618530273,
        10.600000381469727,
        10.5,
        9.699999809265137,
        9.600000381469727,
        10.0,
        10.5,
        12.800000190734863,
        14.300000190734863,
        16.5,
        17.200000762939453,
        18.799999237060547,
        18.899999618530273,
        18.899999618530273
      "name": "Teplota Venku",
      "type": "Double",
      "data": [
        14.600000381469727,
        16.0,
        17.100000381469727,
        17.399999618530273,
        17.600000381469727,
        18.399999618530273,
        19.299999237060547,
        19.799999237060547,
        20.100000381469727,
        19.200000762939453,
        20.100000381469727,
        19.700000762939453,
        20.100000381469727,
        20.5,
        20.799999237060547,
        20.200000762939453,
        20.600000381469727,
        20.100000381469727,
        19.899999618530273,
        19.799999237060547,
        19.5,
        17.100000381469727,
        16.100000381469727,
        15.100000381469727,
        14.699999809265137,
        13.899999618530273,
        14.0,
        13.199999809265137,
        12.899999618530273,
        11.899999618530273,
        11.600000381469727,
        11.100000381469727,
        10.600000381469727,
        10.300000190734863,
        10.0,
        9.5,
        8.300000190734863,
        8.899999618530273,
        7.599999904632568,
        7.5,
        6.800000190734863,
        7.199999809265137,
        6.599999904632568,
        7.300000190734863,
        8.399999618530273,
        10.5,
        10.800000190734863,
        10.899999618530273,
        13.58348377194259,
        15.093332630231913,
        16.603181488521233,
        18.113030346810554,
        19.600000381469727,
        18.200000762939453,
        18.600000381469727,
        18.399999618530273,
        18.799999237060547,
        18.799999237060547,
        18.299999237060547,
        18.5,
        18.200000762939453,
        18.399999618530273,
        18.100000381469727,
        17.799999237060547,
        16.100000381469727,
        15.800000190734863,
        15.199999809265137,
        14.699999809265137,
        13.600000381469727,
        13.300000190734863,
        13.300000190734863,
        13.399999618530273,
        10.800000190734863,
        10.300000190734863,
        9.5,
        9.300000190734863,
        8.800000190734863,
        8.600000381469727,
        8.100000381469727,
        7.900000095367432,
        7.400000095367432,
        7.300000190734863,
        10.399999618530273,
        10.300000190734863,
        10.100000381469727,
        10.199999809265137,
        11.100000381469727,
        11.600000381469727,
        12.300000190734863,
        12.899999618530273,
        14.199999809265137,
        12.600000381469727,
        14.100000381469727,
        14.300000190734863,
        15.199999809265137,
        15.199999809265137,
        15.899999618530273,
        15.800000190734863,
        16.700000762939453,
        17.0,
        18.0,
        17.799999237060547,
        17.299999237060547,
        18.100000381469727,
        18.600000381469727,
        18.100000381469727,
        18.600000381469727,
        18.5,
        18.799999237060547,
        18.299999237060547,
        18.700000762939453,
        18.299999237060547,
        18.0,
        17.200000762939453,
        16.0,
        15.600000381469727,
        14.699999809265137,
        14.399999618530273,
        13.5,
        12.899999618530273,
        12.100000381469727,
        12.300000190734863,
        11.5,
        11.100000381469727,
        10.199999809265137,
        9.800000190734863,
        9.300000190734863,
        9.0,
        14.0,
        14.300000190734863,
        13.899999618530273,
        13.600000381469727,
        14.0,
        14.300000190734863,
        14.699999809265137,
        14.899999618530273,
        15.699999809265137,
        16.200000762939453,
        13.399999618530273,
        14.399999618530273,
        14.399999618530273
      "name": "TempOut1",
      "type": "Long",
      "data": [
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null
      "name": "TempOut2",
      "type": "Long",
      "data": [
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null,
        null
Hi, @etlikmilos Have you found the solution to this particular problem. If yes, please share it with me as I am also facing the same issue.
Hi
No No I am still with the problem.
I think that problem has something to do with locales. Try setting your machine/designer’s locale to EN_US and see if that still happens.
When I change localization in windows on my computer everything is the same. I tried changing localization on the server windows 2008 where is installed ignition and it was still the same :frowning:
It is quite disappointing. @moderators Please have a look at it.
Scratch that. I didn’t see your data block which appears to be formatted in an EN-US way. strange.
This forum is not support. I recommend opening a ticket with support if you can’t figure it out.
Thanks, @pturmel. I am gonna open a ticket with support. Hopefully, my issue will be resolved soon.
Please report back with what you find out, so that others with a similar issue can be helped.
