Number Formatting in Perspective 8.3
I am building a View in Perspective, Ignition 8.3
The View is using a Progress Bar Component. The Progress Bar Component is being used to construct a number of embedded views.
The issue is that with number formatting, I need the currency to be GBP (£) and not USD ($). Is there a way to do this in Ignition out of the box?
The number format in my component’ properties is ‘$ #,##0.00’ which works just fine.
When i change the number format in my component’ property to be ‘£ #,##0.00’ then nothing displays. is there a way to handle this case to display the GBP symbol??
Thank you in advance
You can do it if you change the session variable locale : en-GB (but en-UK doesn't work) while leaving the format string as $0,0.00.
This trick will not accommodate mixed currencies on various progress bars though.
There should be a way of adding the prefix in CSS using the ::before{content:"£";} syntax, but I can't figure it out.
