A customer currently has a gateway with several projects on it. I will be adding at least one new vision project onto that gateway with the possibility of eventually adding another three vision projects onto that gateway. Is there a limit to how many projects you can add to a gateway? Is it dependent on how big the projects are? Is there way to determine the current status of the existing gateway, say add the one new project, look at the same information after the new vision project is added, and then use that information to determine if adding another three similar vision projects would be an issue?
“You can create as many projects as you want, and users can easily jump between projects on the fly or open multiple projects at the same time” . Quoting from the ignition documentation.
Read it here.
