I’m trying to change the colour of an object based on a value, but what I’m trying to achieve doesn’t seem possible with the standard Number-to-Color Translation feature.
I’m trying to achieve the following:
Value=0, colour 1
Value=+ve number up to 100, colour 2
Value= greater than 100 up to 200, colour 3
The problem is if I put an entry of 0 in the translation table, it considers any number from 0 to the next entry as one case i.e. it doesn’t consider 0 as a separate case.
Is it possible to do this? I tried putting in an entry of 0.001, but it doesn’t accept floating point numbers, even though the value being compared is a float.
Al
You’re right, the number-to-color binding doesn’t play well with floating point numbers.
You have 2 options:
- Use the Styles feature - it handles floating point much better.
- Use an expression, with some nested if() functions and the color() function, you can acheive this logic simply.
Thanks for the tips Carl. Styles do handle floating point numbers
- but only to 2 decimal places
. This means it may not work correctly, as the limit should really be the smallest possible floating point number.
Nested if() statements worked, although the 10 closing brackets are a bit mind boggling! It’s a shame the number-to-color binding doesn’t work. The only way I could see it working in this situation is if you allow the selection of ‘>’, ‘=’ or ‘>=’ for each entry.
Al
