numberFormat expression in Numeric Entry Field error
Hello guys, I'm facing with this problem:
I simply add a Numeric Entry Field and I would like to format it with 2 integer, so for example "06".
I try to play with the format property without success and then I also try to add at the value property the expression
numberFormat({this.props.value}, "00")
but I have the error
Error_CycleDetected
How could I manage this?
Thank you very much
You don't need to manually format the value of a numeric entry field.
You can use the built in property format: 00
I don't know what I tried before. I was sure to have test it and cannot be able to make it works, but actually now is working. For sure it's my fault.
Thanks for your time.
