Numeric Display
I’m passing some data from an SQL database to Ignition and then to a PLC. The number in the database is 3 digits and the PLC needs to see the same 3 digits. I would like ignition to display the number /100. Is there an easy way to accomplish this?
SQL value = 834
PLC receives 834
Ignition Displays 8.34
You can use an Expression binding on the Value property of your component. Try this:
{Tag/Path}/100
This would show the quotient on your component, but wouldn’t change the value that PLC receives.
you can also set up linear scaling on your tag. something like raw max = 10000 scaled max = 100
