Numeric Entry Field Covers Up Numbers When Editing
The Numeric Entry Field is covering up the numbers when trying to edit the value. This makes it hard to see the number. I don’t think it used to be this way, so I’m wondering if a recent update did something to this field.
Is anyone else experiencing this? Is there a way to fix it besides switching to button mode? It works correctly in button mode:
We are running in Ignition 8.1.18 with Perspective version 2.1.18.
You could turn off spinner
Regardless, that shouldn’t happen in my opinion
You can add the paddingRight style parameter:
A setting of 20 pixels will probably render the result you want (if you want to keep the spinner):
Well… that was too easy. I don’t know why I didn’t think about adding padding. I would like to leave the spinner on, so padding works great. Thank you!
