Hey victordcq, here’s the JSON for those text fields - in my above picture, I re-used this through an embedded view.
"custom": {
"HighLightFrame": false,
"Language": "",
"ValueInit": 1,
"ValueInitFirstScan": false,
"ValueOld": "",
"_Version": "V6.6.00"
"params": {
"Descr": "---",
"Enable": true,
"Path": "---",
"Property": "Value"
"propConfig": {
"custom.HighLightFrame": {
"persistent": true
"custom.Language": {
"persistent": true
"custom.ValueInit": {
"persistent": true
"custom.ValueInitFirstScan": {
"persistent": true
"custom.ValueOld": {
"persistent": true
"custom._Version": {
"persistent": true
"params.Descr": {
"paramDirection": "input",
"persistent": true
"params.Enable": {
"persistent": true
"params.Path": {
"persistent": true
"params.Property": {
"persistent": true
"props": {
"defaultSize": {
"height": 20,
"width": 190
"root": {
"children": [
"meta": {
"name": "Rectangle1"
"position": {
"height": 20,
"width": 70,
"x": 120
"propConfig": {
"props.style.backgroundColor": {
"binding": {
"config": {
"expression": "if ({view.custom.HighLightFrame},1,0)"
"transforms": [
"fallback": "#FF0000",
"inputType": "scalar",
"mappings": [
"input": 1,
"output": "#6666CC"
"input": 0,
"output": "#A6A6A6"
"outputType": "color",
"type": "map"
"type": "expr"
"type": "ia.container.coord"
"meta": {
"name": "txtDescription"
"position": {
"height": 20,
"width": 100
"propConfig": {
"props.text": {
"binding": {
"config": {
"expression": "if ({session.custom.DesignerMode},\r\n\t\"---\",\r\n\t{view.params.Descr})"
"type": "expr"
"props": {
"textStyle": {
"classes": "CommonElements/NormalText",
"textAlign": "right"
"type": "ia.display.label"
"meta": {
"name": "STD_EventLogging"
"position": {
"height": 20,
"width": 20,
"x": 100
"props": {
"path": "TPM/CommonElements/Functions/STD_EventLogging"
"type": "ia.display.view"
"meta": {
"name": "NumericEntryField"
"position": {
"height": 20,
"width": 70,
"x": 120
"propConfig": {
"props.enabled": {
"binding": {
"config": {
"path": "session.props.auth.authenticated"
"type": "property"
"props.value": {
"binding": {
"config": {
"bidirectional": true,
"fallbackDelay": 2.5,
"mode": "indirect",
"references": {
"Path": "{view.params.Path}",
"Property": "{view.params.Property}"
"tagPath": "{Path}/{Property}"
"type": "tag"
"props": {
"placeholder": "\u0027null\u0027",
"spinner": {
"enabled": false
"style": {
"backgroundColor": "#FFFFFF",
"type": "ia.input.numeric-entry-field"
"events": {
"dom": {
"onMouseUp": {
"config": {
"script": "\tif self.view.params.Value !\u003d self.view.custom.ValueOld and not ((self.view.custom.ValueInit \u003d\u003d True and self.view.custom.ValueInitFirstScan) or self.view.custom.ValueInit) and self.view.params.Enable:\n\t\tself.getSibling(\"STD_EventLogging\").props.params.EventType \u003d 3\n\t\t\n\t\tself.view.custom.ValueOld \u003d self.view.params.Value\n\t\tself.view.custom.ValueInitFirstScan \u003d False\n\n\twhile self.view.custom.ValueInit \u003d\u003d True:\n\t\tif QualityOf(self.view.params.Value) \u003d\u003d \"Good\":\n\t\t\t\t\tself.view.custom.ValueOld \u003d self.view.params.Value\n\t\t\t\t\tself.view.custom.ValueInit \u003d False\n\t\t\t\t\tself.view.custom.ValueInitFirstScan \u003d True\n\t\t\t\t\t"
"scope": "G",
"type": "script"
"system": {
"onStartup": {
"config": {
"script": "\tself.view.custom.ValueInit \u003d 1\n\t"
"scope": "G",
"type": "script"
"meta": {
"name": "root"
"props": {
"style": {
"overflow": "visible"
