Hi All,
Just upgraded to 8.1.5, and the problem has occurred after that.
Numeric entry fields are not diplaying properly when opened via workstation.
When in the designer, or when opening the url, everything displays correctly?
As displayed in Workstation-
As displayed when opening the url-
Designer displays correctly and set to “currency”
Any suggestions?
If you bind a label to session.props.locale does it display anything unexpected in workstation? It looks like your locale is being set to UK English in workstation for some reason. It should just follow the project setting under Perspective > General > Project Locale though just like any other Perspective session.
Returned en-AU as expected.
However I changed the locale to English(Australia) and the problem has been resolved.
Thank you.
