Numeric Entry Field up/down arrow
Hello,
How can I remove the up/down arrow of Numeric Entry Field that appears when you clic on it, in Perspective?
Thank you for the answer.
Your best bet is CSS, but I’m not even sure that will work.
@victordcq @pascal.fragnoud either of you have a trick up your sleeves?
There should be a property called “spinner” you can turn it off. Its new since version 8.1.12.
Thank you for your answer.
I will upgrade my version and try your solution.
