I am trying to use a Numeric Label and have it appear the same as a Numeric Text Field. The problem is that the Font is always Bold for the Numeric Label, regardless of the setting.
I am Using Font set as “Dialog, Plain, 12”.
On the Numeric Text Field when toggling the Bold checkbox it changes back and forth.
But on the Numeric Label it ignores the checkbox and always shows bold. Seems to do this for every font I tried also.
Check the Prefix and Suffix property of your Numeric Label.
If they are <HTML><B> as Prefix and </B> as Suffix you have to remove them, since those are the HTML tag for BOLD.
Thanks! I so rarely use those 2 fields that I didn’t even think of that.
Wonder why the Numeric Label has that added by default…
