Ignition 7.9.11, I have some of Numeric Text Field objects with light blue background.
I want the client only read a value so I remove a V from Enabled property and then I see gray background.
There is another way read only value without change background?
picture:
Thanks.
Use a label instead.
OK, Thanks
If you find yourself thinking that a piece of information should be read-only, then you should probably only be looking at display components.
