Object has no attribute 'append'
tableDS.append([defect, count, level]) line giving me issues saying object has no attribute 'append'.
Honestly stuck as this was working code and now it's not.
Thanks!
def defineLevel(count):
		if count >= 0 and count < 3:
			level = 0
		if count >= 3 and count < 5:
			level = 1
		if count >= 5 and count < 8:
			level = 2
		if count >= 8:
			level = 3
		return level
	end = system.date.now()
	start = system.date.addHours(end, -8)
	params = {"start":start, "end":end}
	ds = system.db.runNamedQuery("QualityDisplays", "Escalation/Table", params)
	tableDS = []
	headers = ["Defect", "Count", "Level"]
	for i in range (ds.getRowCount()):
		defect = ds.getValueAt(i,0)
		count = ds.getValueAt(i,1)
		level = defineLevel(count)
		tableDS = system.dataset.toDataSet(headers, tableDS)
	system.tag.write("[.]Active Dataset", tableDS)
You are changing tableDS to a dataset each loop, unindent the last line of the loop
should be
Edit: I agree with what Tim said below, don't reuse variables, just make another.
I think it is an indent issue. You assigned tableDS to an empty list and then append to it on every iteration. But you reassign it the result of the toDataSet so in the second iteration it is no longer a list, it is a DataSet.
But you probably only intended to do the toDataSet once after the loop had finished.
The moral of the story: don't reuse variables.
