I’m looking for a method to move an object within a template based on a property of the template itself. (i read this: Moving Template inside window based on tag value in Ignition 8 - Ignition - Inductive Automation Forum)
I figured out how to move objects with system.gui.transform but I didn’t understand when to trigger the script.
I try in a property change event but is fired only when the property is really change in runtime! how to do first time? is not clear for me
is possible
if event.propertyName == 'ROT':
if event.newValue == 0:
xPos = 7
yPos = 18
elif event.newValue == 90:
xPos = 15
yPos = 48
elif event.newValue == 180:
xPos = 7
yPos = 34
else :
xPos = 0
yPos = 48
system.gui.transform(component=event.source.getComponent('Label_MID'), newX=xPos, newY=yPos)
