Obtaining Ignition Gold Certificate
Hello All,
I have completed my Ignition core certification and I need to pursue the Gold certificate from Ignition so what are the next process to pursue the gold certificate.
Thanks,
Kartik I
You just need to know SQL first and then start the test. This test is design to force you work with databases a lot and at the end you will see your knowledge is improved a lot.
