OCAP (Out of Control Action Plan) in Ignition
Has anybody used the SFC module to implement interactive OCAP functionality into Vision? Something that operators could use to click through and answer questions to help troubleshoot a process and get it running correctly again. It seems like user interactivity isn't what the SFC module is designed for, so would it be a better idea to just make a custom solution with scripting? Open to any idea/suggestions, thank you!
An example OCAP flowchart:
You should script this. SFCs run in the gateway, not in Vision clients.
