ODBC-JDBC and Foxboro AIM*Historian ODBC Provider
I have an XP workstation with all the stuff from Foxboro installed (AIM*Historian V3.3). Tools from Fox are working and I need to connect via jdbc-odbc connector to the historian.
So, I’ve created a system dsn on this machine (wich hold fox tools and Ignition gateway). This dsn is called ‘histfb’.
To verify if the dsn is okay, I tried to pull data from Excel with external data using the dsn ; everything went ok.
I create the database connexion in the gateway with the dsn but no way to have it working.
Can you help me ?
Enclosed : errors messages, dsn configuration (registry extract)
Tia
odbc-conf.txt (27.1 KB)
It looks like that ODBC driver isn’t very compatible with the ODBC-JDBC bridge.
I highly suggest you use a pure-JDBC driver connect instead of the ODBC connection.
Hello,
wanted to ask you if you were able to figure out how to connect your Foxboro AIM server to ignition? I am trying to find a way to connect it and retrieve data.
Thank you!
Wow, I can't quite remember all the details… sorry about that.
Fifteen Years later. Oy!
