I updated my Ignition test machine to 7.2.5 production version and the context would not load due to the OEE Demo modules not loading. Specifically, the “Production Simulator-module.modl” module would not start up. I ended up deleting it to get the test server running.
Its possible it could also be the xopc-drivers had issues loading but deleting the prod-sim module allowed my server to boot again. I did have the original beta installed here and dont think I updated from the first module. I did try deleting all of the OEE modules and update with latest but it came back though its possible I missed it the first time. During the second round I deleted all of the old modules and it started.
Anyway this is not critical to me since I was just evaluating the OEE module and do not need it running and thought I’d at least post it in case it was missed in testing.
INFO | jvm 1 | 2011/04/04 16:53:18 | INFO [ModuleManagerImpl ] [16:53:18,886]: Starting up module productionsimulator
INFO | jvm 1 | 2011/04/04 16:53:18 | ERROR [SRContext ] [16:53:18,886]: Error during context startup.
INFO | jvm 1 | 2011/04/04 16:53:18 | java.lang.AbstractMethodError
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.xopc.driver.common.AbstractDriverModuleHook.startup(AbstractDriverModuleHook.java:61)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2021)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startup(ModuleManagerImpl.java:249)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:777)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:177)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:584)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:176)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:418)
INFO | jvm 1 | 2011/04/04 16:53:18 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:520)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2011/04/04 16:53:18 | INFO [SRContext ] [16:53:18,886]: Ignition["/main", state=STARTING] ContextState = FAULTED
