Hello,
I have Igntion 8.0.5 (in trial on my PC) and I downloaded the OEE module by Sepasoft taking care of picking the one for this version.
I tried also with version 7.9 and the related OEE module.
I installed it, but it’s status is FAULTED.
Here the details
java.lang.Exception: Exception while starting up module “oeedt2gateway”.
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2354)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startup(ModuleManagerImpl.java:397)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1094)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:277)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:666)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:604)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Caused by: java.lang.NoClassDefFoundError: com/sepasoft/production/license/MESModuleLicenseManager
at com.sepasoft.oeedt2.gateway.OEEDT2GatewayHook.startup(OEEDT2GatewayHook.java:36)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2348)
… 12 more
Caused by: java.lang.ClassNotFoundException: com.sepasoft.production.license.MESModuleLicenseManager
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:37)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.loadClass(ModuleClassLoader.java:85)
… 14 more
Any idea of what could it be?
Andrea
