I am using an Omron NX CPU. The pair of characters in each 16 bit word are swapped when the String type is used in the OPC path - "ABCD" becomes "BADC". I tried all the Data Type Modifiers (@BE, @LE, @HL, @LH) but they don't have any effect. Is this behaviour expected?
As a workaround, I am using a derived tag to swap the byte order on reading and writing but ideally I wish the Omron FINS driver can handle this. In comparison, Kepware supports HiLo byte order, LoHi byte order,Only High byte and Only Low byte for their String data type.
