Hey, we are having some issues with tag connections using the new Omron FINS driver.
Currently we are upgrade a project from 7.8 to 8.0.13, running on windows 10. The PLC is a CJ2 using the FINS-TCP connection. The device connection in the gateway is connected and we aren’t seeing any connection issues in the logs.
Some tags with UDT’s just work and some tags within the UDT just need to be disabled and re-enabled for it to start working. Has anyone come across this before?
The only thing i can see as being the common setting is we are reading an INT(16bit) type from the PLC and scaling the tag 100(0)/1 to get a Float - decimal figure. I think this was tag design was due to a previous SCADA onsite that didn’t like 32bit tags.
