Hi Guys,
Is it Possible that Omron CJ2M Series to do simulation with Ignition without actual PLC hardware?
You can’t simulate that plc connection per say. But you can use simulation aids Ignition Third-Party Module Showcase by @pturmel to simulate the data, tags, etc… which the PLC would generate.
If you have your simulator ready, just connect it by creating a device connection using the TCP Driver.
Ignition also has a built in simulator.
