I have just started a large project involving an Omron NJ PLC. I have started using the Omron NJ driver but noticed a pretty large bug with the tag table.
I do an export of tags from Sysmac Studio as instructed by the Ignition help. Importing the text file works fine and will generate all the tags needed in the table.
However when i click the “Save Changes” button, the Ignition Gateway throws up an “[color=#FF8000]Internal Error[/color]” page.
I have discovered that this results in the tag table not being saved to the gateway, because any time i Enable/Disable the Device or restart the gateway, the tag table is lost.
